Archicad 27 system requirements
ananas
Hi!
Does Archicad 27 works more optimized and actually needs less PC power (CPU, RAM...) then Archicad 26?
Archicad 26:
Archicad 27:
Going by those specs it looks like the more mid-range to high end specs for 26.
Having said that it does run OK on my machines (see specs in signature).
I haven't noticed any difference to running 26, although I must admit I have only been testing it with residential housing projects, and haven't done anything on a large commercial scale.
Alexandre Mocan
What about the CPU? It's very vague to give only the range (i7 or i9). Should we really opt for a CPU with the highest Turbo Max? So an i7 with a higher Turbo max than an i9 with more cores but a lower turbo would be less efficient on Archicad?
