2025-02-04 04:21 AM
With the recently released update for the Archicad 28 Library how can we quickly identify which are the Library Packs that will need to be updated on our BIMcloud instances?
I don't want to have to go through each of the 70 libraries and try and update them to find out if there are any changes. Is there a bulk check for updates ability for the Manage BIMcloud Libraraies dialog?
2025-02-04 05:27 AM
Well that is a bit of a disappointment.
I thought these library packs were supposed to make updating simple.
I would have assumed that only those that needed to be updated would be, but every library pack has been updated.
The only way I can see to figure out what has changed is to keep a copy of the old library and then compare file sizes.
I don't know how BIMCloud works as I don't use it.
If the libraries are all on the local hard drive, there should be no real issue in updating.
But if you have them all loaded in BIMCloud, you may need to replace them all which might be a pain.
It could be possible that a library has changed but the file size remained the same size?
And now I have to figure out how to add the mapping values for the new parts to my template, or do I have to me-map all of the libraries?
2025-02-04 08:29 AM
I had the exact same thought when I saw the video for the update come in an installer.
We need two things:
1. A zip package of only the libpacks that have been updated
And/or
2. The ability to seamlessly update Bimcloud library libpacks with their updated version.
Still struggling to see the advantage that libpacks are bringing us other than the proported ease for the gshq gdl devs to release updates... It's now more complicated for users than the old monolithic library in so many ways....
2025-02-05 06:13 PM
Hi @Matthew Johnson and All,
The following packages got updated in AC28 Library Update 1:
New features:
Doors and Windows
DW Macros
Plants and Outdoor Accessorires
Bugfixes, small changes:
Annotation Elements
Doors and Windows DACH
Doors and Windows JPN
Doors and Windows SWE
Doors and Windows USA
Library Part Maker
People
Skylights
Vertical Transportation Structures
Only translation changes:
2D Symbols SWE
Accessories Library
Annotation DACH
Annotation JPN
Annotation NOR
Annotation RUS
Appliances
Basic Shapes and Special Constructions
Beds
Cabinets and Shelves
Chairs
Chimneys and Fireplaces
Classical Architectural Elements
Couches and Sofas
Curtain Wall
Decoration
Electric Symbols SWE
Electric Symbols
Electrical Equipments JPN
Escape and Rescue Symbols, Safety Notes
Furniture Layouts
Furniture Macros
Furniture SWE
Graphic Symbols
Kitchen
MEP Library
Medical Equipment
Object Macros
Office and School Equipment
Opening Symbols
Plumbing Fixtures and Bathroom
Roof Constructions
Stair and Railing
Steel Constructions
Sun Protection
Tables
Transportation and Parking
Turning Curves CHE
Turning Curves
Wall Ends and Wall Structures
Wall Extras
Wood Trusses
You can download these packages zipped here: https://graphisoft.sharefile.com/public/share/web-sbc814972751441b8a36eecbf036f8941
The Global Library workflow will be further developed in the upcoming versions to make it smooth both in Local and in BIMcloud environments.
AC28 Library Update 2 will be released together with AC28 UP1 and they will contain the following fixes:
The smoother workflow in the future will include the possibility to set library defaults for good (there will be no need to use the mapping tables during updates). Being able to load only the changed libpacks is on our Roadmap too. We understand if you prefer to install the updates only when these improvements are done.
Until then what you can do on BIMcloud to use the libpacks:
Best regards,
Magdolna
2025-02-05 09:56 PM
- Libpack name localization (Because of this item, in AC28 Lib Up 2 all libpack will change)…
Can you expand on what are the implications of this change? Do we need to redefine everything again?
another Moderator
2025-02-06 12:00 AM
- Open the "Manage BIMcloud Libraries" dialog.
- Select all libpacks on the server (use Ctrl/Cmd+A) and delete them.
Unfortunately mulitple slection in the Manage BIMcloud Libraries dialog does not work currently. You can only select one library at a time.
To delete multiple libraries you need to use the BIMcloud Manager.
This is not a good workaround.
2025-02-06 08:36 PM
Hmm:
Check Updates:
Install
So which one is it?
another Moderator
2025-02-07 06:56 AM
Same thing happened to me:
This is just a regular update inside AC. I switched to Collaborate so I too want the BIMcloud updates to be easy and automatic. For now I am sticking with the MonoLibs since the GlobLib system is clearly not finished.
2025-02-23 08:35 PM
@Magdolna Marosvari wrote:The Global Library workflow will be further developed in the upcoming versions to make it smooth both in Local and in BIMcloud environments.
- Multi-selection possibility on BIMcloud libraries dialog
- Dependency handling of libpacks on BIMcloud server
- Possibility to load libpacks to any folder on TeamWork
Hello @Magdolna Marosvari.
I am happy to see some improvements coming to the Global Library system. In addition to what you mention, the most requested feature during the beta and tech preview stages is the ability to load (or link to) a folder that contains multiple libpacks, like we have always been able to do with monolith libraries. Is this on your roadmap? If not please consider it.
Another thing that was promised in the testing phases was better utilities to manage the added complexities of the global libraries, along with more thorough documentation. Specifically:
I look forward to your insights. Thanks.
2025-02-25 04:14 PM
Hi @SeaGeoff ,
Thank you for your feedback.
Indeed the Mapping Tool is a much needed development and it has high priority. Setting the defaults for multiple objects simultaneously and the parameter picker are really good ideas, thank you for sharing them. They are definitely considered. The tool itself can be expected after AC29.
Regarding the documentation about virtual folder hierarchy:
You can find Global Library Documentation here: https://graphisoft.com/resources-and-support/downloads?section=bim-content
and if you search for the 'path name table' section, you can find this description: https://gdl.graphisoft.com/tips-and-tricks/creating-pathnametable-json
I hope it helps.
Regarding loading multiple libpacks: I hope that the multi-selection possibility (coming with Archicad 28 Up 1) will make library management significantly easier. But further usability improvements can be expected later too. Let us know any specific wishes.
Best regards,
Magdolna
