Installation & update
Archicad 28 Library Update - Updating Library Packages to a BIMcloud
Matthew Johnson
With the recently released update for the Archicad 28 Library how can we quickly identify which are the Library Packs that will need to be updated on our BIMcloud instances?
I don't want to have to go through each of the 70 libraries and try and update them to find out if there are any changes. Is there a bulk check for updates ability for the Manage BIMcloud Libraraies dialog?
Matthew Johnson - POWE Architects
AC4.5 --> AC28 & Revit 2016 --> 2023
Asus Zenbook Pro 16x i9-13900H w/ Nvidia RTX 4070 4K dual, Windows 11 64bit + Quest3
I'd rather be sailing.
8 REPLIES 8
Well that is a bit of a disappointment.
I thought these library packs were supposed to make updating simple.
I would have assumed that only those that needed to be updated would be, but every library pack has been updated.
The only way I can see to figure out what has changed is to keep a copy of the old library and then compare file sizes.
I don't know how BIMCloud works as I don't use it.
If the libraries are all on the local hard drive, there should be no real issue in updating.
But if you have them all loaded in BIMCloud, you may need to replace them all which might be a pain.
It could be possible that a library has changed but the file size remained the same size?
And now I have to figure out how to add the mapping values for the new parts to my template, or do I have to me-map all of the libraries?
scottjm
I had the exact same thought when I saw the video for the update come in an installer.
We need two things:
1. A zip package of only the libpacks that have been updated
And/or
2. The ability to seamlessly update Bimcloud library libpacks with their updated version.
Still struggling to see the advantage that libpacks are bringing us other than the proported ease for the gshq gdl devs to release updates...  It's now more complicated for users than the old monolithic library in so many ways....
Magdolna Marosvari
Hi @Matthew Johnson and All,
The following packages got updated in AC28 Library Update 1:
  • New features:
    • Doors and Windows
    • DW Macros
    • Plants and Outdoor Accessorires
  • Bugfixes, small changes:
    • Annotation Elements
    • Doors and Windows DACH
    • Doors and Windows JPN
    • Doors and Windows SWE
    • Doors and Windows USA
    • Library Part Maker
    • People
    • Skylights
    • Vertical Transportation Structures
  • Only translation changes:
    • 2D Symbols SWE
    • Accessories Library
    • Annotation DACH
    • Annotation JPN
    • Annotation NOR
    • Annotation RUS
    • Appliances
    • Basic Shapes and Special Constructions
    • Beds
    • Cabinets and Shelves
    • Chairs
    • Chimneys and Fireplaces
    • Classical Architectural Elements
    • Couches and Sofas
    • Curtain Wall
    • Decoration
    • Electric Symbols SWE
    • Electric Symbols
    • Electrical Equipments JPN
    • Escape and Rescue Symbols, Safety Notes
    • Furniture Layouts
    • Furniture Macros
    • Furniture SWE
    • Graphic Symbols
    • Kitchen
    • MEP Library
    • Medical Equipment
    • Object Macros
    • Office and School Equipment
    • Opening Symbols
    • Plumbing Fixtures and Bathroom
    • Roof Constructions
    • Stair and Railing
    • Steel Constructions
    • Sun Protection
    • Tables
    • Transportation and Parking
    • Turning Curves CHE
    • Turning Curves
    • Wall Ends and Wall Structures
    • Wall Extras
    • Wood Trusses
You can download these packages zipped here: https://graphisoft.sharefile.com/public/share/web-sbc814972751441b8a36eecbf036f8941
The Global Library workflow will be further developed in the upcoming versions to make it smooth both in Local and in BIMcloud environments.
AC28 Library Update 2 will be released together with AC28 UP1 and they will contain the following fixes:
  • Multi-selection possibility on BIMcloud libraries dialog
  • Dependency handling of libpacks on BIMcloud server
  • Possibility to load libpacks to any folder on TeamWork
  • Libpack name localization (Because of this item, in AC28 Lib Up 2 all libpack will change)
The smoother workflow in the future will include the possibility to set library defaults for good (there will be no need to use the mapping tables during updates). Being able to load only the changed libpacks is on our Roadmap too. We understand if you prefer to install the updates only when these improvements are done.
Until then what you can do on BIMcloud to use the libpacks:
  1. Open the "Manage BIMcloud Libraries" dialog.
  2. Select all libpacks on the server (use Ctrl/Cmd+A) and delete them.
  3. Create a new project using the AC28 template.
  4. Share the project to BIMcloud; this will upload all the newer libpacks to the server.
Best regards,
Magdolna
Eduardo Rolon
  • Libpack name localization (Because of this item, in AC28 Lib Up 2 all libpack will change)…
Can you expand on what are the implications of this change? Do we need to redefine everything again?
Eduardo Rolón AIA NCARB
AC28 US/INT -> AC08
another Moderator
Unfortunately mulitple slection in the Manage BIMcloud Libraries dialog does not work currently. You can only select one library at a time.
To delete multiple libraries you need to use the BIMcloud Manager.
This is not a good workaround.
Eduardo Rolon
Hmm:
Check Updates:
Install
So which one is it?
AC28 US/INT -> AC08
another Moderator
SeaGeoff
Ace
Same thing happened to me:
  1. No update alert when launching AC. I heard about it from a friend.
  2. DL'd and ran the updater.
  3. After the update Check for Updates still says Update Available but the installer says I'm already updated.
This is just a regular update inside AC. I switched to Collaborate so I too want the BIMcloud updates to be easy and automatic. For now I am sticking with the MonoLibs since the GlobLib system is clearly not finished.
Regards,
Geoff Briggs
I & I Design, Seattle, USA
AC7-28, M1 Mac, OS 15.x
Graphisoft Insider's Panel, Beta Tester
Hello @Magdolna Marosvari
I am happy to see some improvements coming to the Global Library system. In addition to what you mention, the most requested feature during the beta and tech preview stages is the ability to load (or link to) a folder that contains multiple libpacks, like we have always been able to do with monolith libraries. Is this on your roadmap? If not please consider it.
Another thing that was promised in the testing phases was better utilities to manage the added complexities of the global libraries, along with more thorough documentation. Specifically:
  • We need a tool for editing mapping tables, which is nightmarish to perform in a text editor. Such a tool should enable us to modify the defaults of multiple objects simultaneously when they share the same parameters, like changing a surface in all doors and windows. And ideally it could pickup parameters of a placed instance or favorite and apply those to all similar objects.
  • There is no documentation I can find about the virtual folder hierarchy, how it is set, and how to merge our office libraries with the chosen localization.
I look forward to your insights. Thanks.
Regards,
Geoff Briggs
Setup info provided by author
