Installation & update
Archicad Crashes When performing Interior Elevations
New User Here!!!!
I Don't know what I'm Doing Wrong But Archicad 8 crashes after doing all the steps to get to the interior elevation command...it crashes on the half way on the processing of the interior elevation box...
I'm Using a Dell Inspiron 8200 XP Home 512MB P4 mobile 2.2Mhz. ATI 9000 Radeon Graphics Card...
I've already updated the graphic card Driver...and the problem persists!!!
also I've performed the compatibility graphic card test and it when pretty good.
What Could be wrong?
Please Help Me!!!!
Rob
What is the version of your AC mate?
as I can remember there was a problem with the internal elevation tool on AC8.0 - sometimes it has simply crashed...
if you have AC8.0 get upgraded to 8.1 (free upgrade) - problem solved, if not you have to be more specific about what you are doing...
::rk
Thank You ROB !!
YES INDEED I'm Using AC 8 (first release) I should get AC8.1 !!!
I do believe upgrading will be the solution.
But Where can I get AC 8.1 upgrade for free?
Is it directly at graphisoft?
Thank You!!!
Eduardo Rolon
You should have received a CD directly from Graphisoft, if not talk to your reseller. Also make sure you download the R2C revision for 8.1 and it's library
Eduardo Rolón AIA NCARB
AC28 US/INT -> AC08
another Moderator
