Archicad keeps crashing after Catalina upgrade - SOLVED
**Help** I upgraded to Catalina and now every time I go to edit text or add labels in the elevation view it crashes. It's now crashing anytime I edit text at all not just elevations. I looked online and found a Reddit thread with others who are having the same issue...is anyone else experiencing this and/or are there any work arounds until it gets fixed? Thanks.
**UPDATE - I NEEDED TO DOWNLOAD THE UPDATES - WORKS GREAT NOW!
12 Replies 12
Did you update your Codemeter driver ?
The link
Why did you change your OS ?
I don't understand updating an OS without knowing what does it mean.
Christophe - FRANCE
Formateur Archicad indépendant à NANTES, PARIS
Archicad 15 to 29
DGSketcher
Legend
Have you got the latest AC updates loaded?
I did a clean install of Catalina before only installing AC23, I have very few problems with it, typically minor graphic issues. I am working in solo mode (no teamwork).
That fixed it thank you!
Can you tell me how you solved this problem?
Eduardo Rolon
He updated AC and the Wibu drivers as inidcated on the posts
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
I have updated AC. How do I update the Wibu drivers?
They seem to be unto date but I can't be sure?
Ignore the previous message I found the driver on the Graphisoft website.
I have updated but still the same problem
Ok. I have updated Catalina, I have updated the Wibu drivers and I have the latest update for AC21.
It is still crashing when I use the text tool.
Can anybody help?
I am running IMac 3.2 GHz Intel i5 with Catalina 10.15.7
Lingwisyer
Guru
Jason wrote:
Can anybody help?
If it was a fix in a AC23 or 24 update, you are on the short end as that would imply a clash between AC and Catalina, which would not be resolved in AC21 as Graphisoft only supports the previous two(?) versions. Would have to get input from someone in GS regarding whether that is the case or not for this issue.
Ling.
