dnathanc
Archicad stalling out on quit.
Constantly having issues with the program freezing when trying to quit, especially with larger files / models.  More of a nuisance than a serious problem, but it is frustrating to have to send a bug report nearly every time leaving the program.  And have lost work before if I forgot to save before quitting.
Anyone else ever experienced this?
Using AC 26 on MacBook M1 Pro with Sonoma 14.5.
4 Replies 4
Do you have the latest update for 26?
Build 7004.
dnathanc
Believe so. This is what comes up when I check for update from inside program.
All up to date.
I just did a quick search and found a few posts with the same problem (most for older versions) and the only solution I saw was to update.
If it is not happening to all files, then all I can suggest is you open the files from the file menu with the 'Open & Repair' option to see if that helps.
If not, take note of the bug crash number, and contact you local Archicad support and ask them to follow it up.
dnathanc
Thank you, will give that a shot.
