NarsilEa
cineware not rendering
Hello everyone!
I am using Archicad 29 and for no reason my cineware has stoped working, well it does work but it used to take 5 sec to render an image and now it takes ages and basically i have to quit the process each time... for no reason at all!
I am using  Asus Rog Zephyrus G15, with RTX 3070 and it used to go extremely fast before this . I have checked my GPU and RAM and everything work fine from Hardware-based option!!
thank you in advance!!
Setup info provided by author
4 Replies 4
Try using a different render scheme.
I don't have Archicad with me at the moment so I can't remember their names, but try a 'fast' one instead of a 'final' one.
NarsilEa
i will give it a try
NarsilEa
So just an update , it looks like the project is "heavy" or somehow to much "complicated" , which is not!
i gave it a try to render in a new simple project and it worked. but in mine didn't .
is it a way to chech and "clear" my curent project?
Karel Landa
There will probably be a too much complex object or some textures which causes this.
Try to turning off layers in bulks so you can find layer in which the problematic object/texture is.
Also, to easily say if it is object or texture, try set Graphic overrides so the whole model is with one texture (colour).
From Archicad 17
MacBook Pro M1 Max
