2025-12-29 08:54 AM - last edited on 2025-12-29 03:07 PM by Eduardo Rolon
Hello everyone!
I am using Archicad 29 and for no reason my cineware has stoped working, well it does work but it used to take 5 sec to render an image and now it takes ages and basically i have to quit the process each time... for no reason at all!
I am using Asus Rog Zephyrus G15, with RTX 3070 and it used to go extremely fast before this . I have checked my GPU and RAM and everything work fine from Hardware-based option!!
thank you in advance!!
2025-12-30 11:03 AM
Try using a different render scheme.
I don't have Archicad with me at the moment so I can't remember their names, but try a 'fast' one instead of a 'final' one.
2025-12-31 03:06 PM
i will give it a try
2026-01-02 08:35 AM
So just an update , it looks like the project is "heavy" or somehow to much "complicated" , which is not!
i gave it a try to render in a new simple project and it worked. but in mine didn't .
is it a way to chech and "clear" my curent project?
2026-01-02 11:05 AM
There will probably be a too much complex object or some textures which causes this.
Try to turning off layers in bulks so you can find layer in which the problematic object/texture is.
Also, to easily say if it is object or texture, try set Graphic overrides so the whole model is with one texture (colour).
