Starting August 6, 2024, TLS 1.2 will be the minimum required protocol version for Graphisoft products and services that require an online connection. Learn more…
Aus template spelling issue AC23
Just noticed this in AC23, probably doesnt matter that much as most people might have their own templates and its something that wouldnt be seen in documents but thought would point it out. For the AUS standard template, the standard folder "Sketch Design" is spelled "Desing"
Wasnt sure where to post it so if this is in wrong area or been pointed out before please feel free to remove or move it.
1 REPLY 1
It would be best to report this to Central Innovation who are your support people in Australia, and the creators of that template.
You should be able to change it and re-save the template if you want to.
