The Archicad user guide which is shipped with the product omits the fact that if you don't populate the company defaults folder in your install point you will not see the advanced option.
Since we want the program as per a standard install we have copied the defaults from a vanilla install on a reference PC.
Running set-up with the -W log.record=yes switch should work after you have populated that folder.
This will create a pre configured install which requires minimal user input.
To run this silently add -silent to the end of command line.
ArchiCAd uses Installshield Universal for deployment which is Java based and multiplatform. great for them but a pain for anyone who needs an MSI for managed distribution.
Graphisoft if you decide to do an MSI based installer, I'll have one along with my hovercar and all of the other 21st century technology which I have yet to recieve
