Installation & update
BUG with Two-Point Perspective still not fixed ?
Steve Jepson
4 REPLIES 4
Minh Nguyen
Graphisoft Alumni
Graphisoft Alumni
Hi Steve,
Thank you for sharing the issue and I am very sorry about the experience!
As far as I understand, this does not look like a bug to me. Two point perspective is a type of linear perspective (a method using lines to create the illusion of space on a 2D surface). Two point perspective uses two points placed on the horizon line.
In this case, since you positioned the camera to look from above (almost as if it was 1-point perspective), the line used for placing 2 points was placed at a very far distance, therefore, the model was "flatten".
I hope my explanation is clear enough. If you have any further questions, feel free to ask me again!
Best regards,
Minh
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
Steve Jepson
Fine. Not a bug. Just a level of distortion I have never seen before.
runxel
Hero
What did you expect to happen? I'm not even sure, what else should happen here.
The 2-point perspective was always just for minor corrections when dealing with "normal" views (like a human would).
Might be an axo suited for this task?
Steve Jepson
I just expected far less distortion - more like this
