Installation & update
BUG with Two-Point Perspective still not fixed ?
4 REPLIES 4
Minh Nguyen
Graphisoft Alumni
Graphisoft Alumni
Hi Steve,
Thank you for sharing the issue and I am very sorry about the experience!
As far as I understand, this does not look like a bug to me. Two point perspective is a type of linear perspective (a method using lines to create the illusion of space on a 2D surface). Two point perspective uses two points placed on the horizon line.
In this case, since you positioned the camera to look from above (almost as if it was 1-point perspective), the line used for placing 2 points was placed at a very far distance, therefore, the model was "flatten".
I hope my explanation is clear enough. If you have any further questions, feel free to ask me again!
Best regards,
Minh
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
Fine. Not a bug. Just a level of distortion I have never seen before.
runxel
Hero
What did you expect to happen? I'm not even sure, what else should happen here.
The 2-point perspective was always just for minor corrections when dealing with "normal" views (like a human would).
Might be an axo suited for this task?
I just expected far less distortion - more like this
