Bizarre Dimension Glitch
Dave Jochum
I opened a file today and found very screwed up dimension strings that I had placed months ago. Some strings have morphed into include additional dimensions to the user origin, and on a different axis, which on some stories is simply out in space! Has anyone else has experienced this weird glitch?
Dave Jochum
J o c h u m A R C H I T E C T S http://www.jochumarchitects.com
MBP 16" (M1 Max) 64 GB•OS 15.3•AC 28 Silicon (latest build)
5 REPLIES 5
Erwin Edel
Nope. Are you perhaps drafting very far away from the origin?
www.leloup.nl
ArchiCAD 9-29NED FULL
Adobe Design Premium CS5
Dave Jochum
No, not at all. The user origin was essentially in the middle of the floor plan. Very strange. I should have taken a screen shot before I fixed it and will if it happens again (though I'll be fuming if it does).
Dave Jochum
I've had the same issue. GS tech support is aware.
Dave Jochum
After weeks of the same 7 or 8 dimensions with this glitch, out of the blue they are now holding.
Dave Jochum
reidweber
I've also been having this issue. When I open a new view, some of the dimension strings are dimensioned to the same seemingly random point. When I select them and changer any of their parameters (i.e. make the text bold, center it, or change the color) the dimension strings jump back to their original locations as if nothing were changed. I've attached an image of how the strings look
This is a very concerning glitch, how do you fix this issue?
Thanks,
Reid
ArchiCAD 24, 25 & 26 US
WINDOWS PC, 16GB RAM, Intel(R) Core(TM) i7-3770 CPU @ 3.40GHz 3.40 GHZ, NVIDIA GEForce GTX 970, ASUS, CM6870, Rev X.0x
