Blank Orbit Screen
I am having a problem orbiting. When ever I click on axonometric view and then to orbit the screen turns black when I try to rotate. It also does this when ever I try to pan as well. Any ideas on how to fix this?
14 Replies 14
I`v made a printscreen with the isssue. It happened after i zoomed the image and then i clicked "O" for orbit. I also had an object selected and it can be seen in wireframe. The screen stays like that until i click another key.
The problem persist with the internal engine as well with the opengl engine and with wireframe mode too
Maybe its not a vital problem but it still annoying because i like when things run smooth and perfect.
It happens because of the evil black background.
No, I am just kidding. I would try to upgrade my graphics card drivers to the latest version as the first step.
Ernest Atanasiu
Since 2009 Intel has not upgraded its laptop graphic drivers (945 and 965). As a result, there is no solution for laptops using Intel integrated graphics.
arch. ernest atanasiu
AC 10-29 INT/GER/FR on Win 11
This does not really help you much but I know that Graphisoft really doesn't recommend systems with integrated graphics:
http://www.graphisoft.com/ftp/marketing/us/05-archicad_dream_machine/05-archicad_dream_machine.video...
vistasp
Mentor
Ideally, you should have a separate graphics card
Having said that, I have managed to run AC-13 on my netbook. It's slow but it works!
= v i s t a s p =
bT Square Peg
https://www.btsquarepeg.com
