Installation & update
Bluetooth Keyboard
Shamla
My new Bluetooth Keyboard Function keys not working as the old USB keyboard. For example, F5 does not "show selection in marquee in 3D". F2 does not activate Floor plan, etc. How can i solve this?
F1, F2 and F3 keys are white with lights. It is a Logitech K375s keyboard.
Shamla
2 ACCEPTED SOLUTIONS
It looks like the f keys are set for when you hit the function key, usually Fn.
If it came with software there might be an option to change it.
Lingwisyer
Guru
On a quick look at the product page, F1 - F3 toggle between linked devices hence the lights to tell you which device you are currently typing to at a glance.
FN + Esc changes the default FN status on Logitech keyboards.
Ling.
Lingwisyer
Guru
Ling.
