Bug reporter problem
I have recently been told that us Aussies can actually send off bug reports. Alas there seems to be a connection problem so that every time I attempt to send it the connection does not work.
If this automatic function is not working where can I send the report file to via email.
Thanks,
Roolio
2 Replies 2
Ben Odonnell
Roolio,
You should send the report to your local dealer or directly to GS OZ.
Don't forget to write down the bug report number for later reference and correspondence with Graphisoft.
HTH.
Cheers.
Ben
Ben O'Donnell
Architect and CTO at BIMobject®
Get your BIM objects from bimobject.com
Thanks mate,
Little unsure what the alternative was.
Roolio
