Thank you for reporting this issue and I am very sorry about the experience!
This is intentional to have these temp files here. These temp files are working as a "cache" - they are created every time you place a point cloud into a plan, in order to work faster with the huge point cloud file. When you close all running Archicad instances which contain point clouds, the files should be deleted. I think the problem here is Archicad was crashed due to low memory before it can delete these temp files normally.
There is an option to disable these temp files, but the point cloud will be loaded directly on RAM. It requires at least 32GB of RAM if you work with large point cloud file frequently. It can be activated via registry:
- Close all running Archicad and check if all the temp files have been disappeared
[list=]Navigate to HKEY_CURRENT_USER\SOFTWARE\Graphisoft\ARCHICAD\ARCHICAD xx...\PointCloud\FilemappingEnabled, and change this key to 0
Thank you for your understanding! I hope this has answered your question. If you have any further issues, feel free to ask me again!
Best regards,
Minh
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
