ARCHI_JWA
C4D EXPORT SETTINGS INVISIBLE ON AC25 !
I just installed the Add-on (C4D) for Archicad 25.
On preview AC editions, I used to access the export settings under "interoperability" - "Cinema 4D export Settings". This enables to active "Surface" or "Element" based export.
This setting window is unavailable. Very Problematic.
Someone has a solution ?
Thanks
3 Replies 3
Steve Jepson
ARCHI_JWA
Thanks for your help.
No Settings were visible anywhere, until I SWITCHED OFF & BACK ON the Cinema Add-on. From then on the settings appeared under Design Extras.
YES !!
Thanks,
Best, Axel.
Steve Jepson
Axil,
I have been wanting to demo a Maxon product but I know nothing about which one would be the best for what I am doing - which is mostly just Rendering of buildings and a few interior sceens modeled with Archicad 25.    Is C4D just one program or do I need to choos some special version ?  It looks like there are about 10 different products under the Render tab.  Which one are you using ?
