2022-11-17 06:28 PM - last edited on 2023-05-26 02:42 AM by Gordana Radonic
I just installed the Add-on (C4D) for Archicad 25.
On preview AC editions, I used to access the export settings under "interoperability" - "Cinema 4D export Settings". This enables to active "Surface" or "Element" based export.
This setting window is unavailable. Very Problematic.
Someone has a solution ?
Thanks
2022-11-17 09:03 PM - edited 2022-11-17 09:05 PM
2022-11-18 10:06 AM
Thanks for your help.
No Settings were visible anywhere, until I SWITCHED OFF & BACK ON the Cinema Add-on. From then on the settings appeared under Design Extras.
YES !!
Thanks,
Best, Axel.
2022-11-18 06:17 PM - edited 2022-11-18 06:18 PM
Axil,
I have been wanting to demo a Maxon product but I know nothing about which one would be the best for what I am doing - which is mostly just Rendering of buildings and a few interior sceens modeled with Archicad 25. Is C4D just one program or do I need to choos some special version ? It looks like there are about 10 different products under the Render tab. Which one are you using ?
