CAN'T OPEN ANOTHER INSTANCE OF AC13 WITH OS 10.7.2 (LION)
dhaval7shah
I can't open another instance of AC13 using OS 10.7.2,
another instance starts opening then stucks.
does anybody have the same problem ?
Dhaval Shah
Upto AC 22
iMacs and MacBookPros: Mac OS X (10.6 to 10.12, Intel core 2 Quad to i5, i7, 8 GB to 16GB)
Win 10, AMD Opteron 6-Core x 2, 16GB, FirePro W4100 2GB
& ThinkPad E550
& i7, 8GB
4 REPLIES 4
Rod Jurich
Just installed 10.7.3, you show as 10.7.2.
No problem in opening a 2nd instance.
Try after you update.
Rod Jurich
Ben Cohen
its happening for me. I am on Lion 10.7.3 and I get a freeze when starting a new instance.
The work around is to launch a new instance using the default template and open the job from there.
Ben Cohen
Mac and PC
Archicad (Latest Version) aus
www.4DLibrary.com.au
dhaval7shah
I also installed 10.7.3 update, same problem continues.
Dhaval Shah
Upto AC 22
& ThinkPad E550
& i7, 8GB
No problem testing here with 10.7.3
I'm starting the new instance via File > New or File > Open with the checkbox to launch another instance.
Maybe your preference files are corrupted? Check the Wiki article on how to clear them out?
One of the forum moderators
