Installation & update
Can I still install Archicad 24?
louisec
I am currently using Archicad 25 but would like to install Archicad 24 also onto my computer, as the other designers in my company are still using 24(!!) & it will save me having to save plans back & possibly losing details. I can only find the updates for 24, not the full install - can anyone tell me if it is still available to download & if so, where to find it? I want the AUS version if possible for Windows. Many thanks.
Use this link ...
https://graphisoft.com/downloads/archicad/install/AC24/AUS
You can change the version number and language code in the link to get any version back to about 18.
You will still need the updates that you have already found.
I still don't understand why Graphisoft does not have links to the old version of Archicad on their websites.
They are obviously available.
4 REPLIES 4
Use this link ...
Thank you so much, Barry! I have been searching high & low for this all morning šŸ˜Š
mthd
Ace
Hi Barry, I am in the process of considering upgrading to the latest version. I wanted to get a demo version of 25 first before trying 26. Do you know how I can get a download for a demo version of AC25 Aus ?
AC8.1 - AC28 ARM AUS + CI Tools
24C GPU 7.8TF 32GB RAM OS Sequoia
Same link as I shared before.
Just change 24 to 25 in the URL.
Without a license the software will only run in demo mode.
So you can try but not save anything.
