2009-06-25 08:35 PM
2009-06-26 01:04 AM
2009-06-26 02:44 PM
vfrontiers wrote:Unfortunately I don't see that being part of the problem...
Most likely you are running out of memory...
2009-06-26 04:12 PM
2009-06-27 02:10 AM
2009-06-27 04:26 PM
guitarchitect wrote:You could try to create a new file (from the template) and then Merge the problem file into it.
I made a new template file to fit the project into, and copy/pasted everything into that. that's when the problems started. if I hotlink all of my stuff back into the old file, it exports just fine... same geometry and everything.
2009-06-27 09:52 PM
2021-05-01 04:28 AM
2021-05-02 05:24 PM
2021-05-05 03:04 AM
