‎2022-07-03 09:00 PM
After making all the login procedures, I cannot continue with my authentication key. My Graphisoft login is done and running okay.
‎2022-07-04 02:54 AM
I just tried and it looks like it does nothing.
But click on the sign in button again and you can go to 'My Profile' where you will probably have to sign in again (I did).
Or just go to Graphisoft ID in the first place ... https://graphisoftid.graphisoft.com/#/login
‎2022-07-06 02:14 PM
Hi all,
Thank you for sharing your experience with this problem!
The Authentication key is needed only when connecting a Graphisoft ID to an end user. If your Graphisoft ID already belongs to a company (which is the situation that you had here), then after signing in, License Manager Tool won't ask for the Authentication key, but will show you the licenses available to you to download from the pool.
I hope this answers your question. Please let me know if you have anything unclear!
Best regards,
Minh
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
‎2022-07-06 05:32 PM
Apparently I just had to update the License Manager Tool. Now everything is okay
‎2022-07-11 12:17 PM
Hi all
I just downloaded Archicad 25, where can I get the license number, please. for students.
‎2022-07-11 12:21 PM
I have Archicad 24, so far the teacher asked to use Archicad 25, it is said that it renders fine.
‎2022-07-11 02:31 PM - edited ‎2022-07-11 02:31 PM
Go to myarchicad.com and fill the required info there to get the license.
another Moderator
‎2022-08-07 09:45 PM
I also have problem with this
when I want to fill the required info unfortunately there is wrote
in This reason I also don't know to what should I do.
‎2022-08-08 12:43 AM
Did you go to https://myarchicad.graphisoft.com and followed the instructions?
another Moderator
