ELEVATE
Cant save file as DWG Option Missing
SAVE AS ".DWG" option Missing. Checked Add-On Manager and there is not option for DWG-DXF in-out?   Also I cant Drag and Drop .DWG files into Archicad like AC27.  PDF's work, But Not DWGS.  Any Idea?  Thank you!
DMD
1 Solution
When you look in your program folders, is the add-on in the 'Import-Export' folder?
If not, maybe you need to re-install?
Go to post
