Installation & update
Changing Display Order Lag/Time Delay
There is an issue in ArchiCAD that has been persistent in the last 5 or more versions, that is when you change the display order of anything, it could be a simple square fill, a zone or a 3D element, there is an inordinate time delay in performing the operation. I have keyboard shortcuts set up for the display order operations:
Bring to Front Home
Bring Forward PageUp
Send Backward PageDown
Send to Back End
And when I want to use any of them I get the busy cursor (pizza of death, we call it) for approx. 10-20 seconds. So if you want to move the display order of an element up three levels, that's a minute of just staring at the screen. I've actually replied to an email in the time it takes to move a fill one level. This adds up to hours of lost time over the course of a project. It used to be virtually instant.
Current platform is Retina iMac 5K 2017 4.2 GHz i7, 24 GB RAM, Radeon Pro 580 8 GB, operating system macOS Mojave 10.14.5 and ArchiCAD 22 Build 6001 UKI FULL, but this bug has been around for years, and on multiple platforms with different work environments.
Is there a known fix for this issue? I've tried quite a few things. If there's not a fix, can this be added to the wishlist for a AC22/23 bug fix or the build of AC24?
DGSketcher
Legend
I have a similar spec Mac and just set these shortcuts up to test. I created a fill and moved it up and down through the display order of a complex model without issue. Is this specific to one file or all projects?
I have attached an image with my settings.
Daniel Kovacs
Graphisoft Alumni
Graphisoft Alumni
Hello Steve,
Next time ARCHICAD freezes like this on macOS, please create 2-3 Process Samples while ARCHICAD is frozen. When you are done, please quit ARCHICAD and collect the Fastlogger Files as well.
If you send me the Process Samples, the Fastloggers, and a description of what you were moving when the freeze happened, I can take a look into this issue for you.
Thanks,
Daniel Alexander Kovacs
GRAPHISOFT
