Installation & update
Convert file from 26
MIMIDU
Anyone can convert me .pln file version 26 to version 22 or .dwg file
You can do it yourself. You can download all Archicad versions from v18 to v26 from here:
https://graphisoft.com/resources-and-support/downloads?section=product&localization=INT&product=arch...
In v26, before saving as v25, make sure to embed all placed Library parts into the Embedded Library of the project because only Library Parts within the Embedded Library can be converted to previous version by Archicad.
Then just save in v25 as v24, save in v24 as v23, then save in v23 as v22.
Not everything may be backsaved because any data within the file that was developed in Archicad after v22 will be lost in the v22 version of the file.
I was going to suggest this.
But I get the impression MIMIDU  does not have version 26?
In which case they should contact the person where the plans comes from and ask them to back save it to 22.
@MIMIDU , you should always go back to the source of the file and ask them to convert it.
I can't install version 26 of ArchiCAD. Only 22 version run to my computer.
