Corrupt PRINT functionallity!
It is a first time I see a bug like that. File/Print command won't work. It accepts ONLY default settings and default printer, any changes made to printer settings are disregarded when confirmed by pressing OK???
Any suggestions? My guess is that it is a hardware problem.
Regards
PS: And, YES, I have reinstalled AC, and it won't work on AC 8.1 either.
18 Replies 18
Ben Odonnell
Ivan,
What is your printer make/model?
Cheers.
Ben
Ben O'Donnell
Architect and CTO at BIMobject®
Get your BIM objects from bimobject.com
Ben wrote:
Ivan,
Cheers.
Ben
It is HP755CM.
It isn't just one printer problem. It's ALL printers problem ( we have like 8 of them), it really accepts ONLY default printer and its default settings. No paper size and orientation adjustments.
Regards
Djordje
This can ONLY be access right settings. Nothing else.
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
Ben Odonnell
It has to be.
As Djordje said, it has to be a privilege problem. Sounds to me that you have limited rights and not Admin rights.
Cheers.
Ben
Ben O'Donnell
Ben wrote:
It has to be.
Cheers.
Ben
Are you saying that in order to work in ArchiCAD you must have full administrative rights on every ArchiCAD PC in your company?
Is it common for all other softwares too?
Regards
Djordje
It all depends how the printers are set up.
If they are shared off a computer (connected to another computer, and shared) then your rights have to be set for them at full control, and you have to be Power user on that computer.
If they are set up directly at the network, with their own IP addresses, than it is also a matter of access and control rights.
Being an Administrator on your computer does not make you Administrator on any other computer.
IT guys usually don't understand whay would you need to do something because they don't have the basic idea what it is that you do, and are extremely jealous of their godlike status ... watch out ...
Djordje
HP Omen
Greg Kmethy
Graphisoft Alumni
Graphisoft Alumni
When you change settings in Print setup, ArchiCAD tries to read data from the driver files. these are in the C\ WINDOWS\ systemthirtytwo\ spool\ drivers folder. Do you have read&execute rights to this folder and to the items in it?
Sorry, it seems that the AC-Talk server does not allow me two spell systemthirtytwo with numbers. It gives me a security alert.
Gergely Kmethy
As long as I feel safe on your server I don't mind .
I am sorry to push this topis further but this is a big issue to me. Please check security settings for the folder you mentioned, for me it look like I have full administrative rights.
In regard to Djordje's reply I clearly doubt that I will get full IT administrative rights ever, as it will stay with our IT.
Regards
Our IT have tracked the problem and reported it for our forum. This should be in PROBLEM/SOLUTION section or ArchiGuide.
Regards here it goes:
______________________
User experiencing problems selecting and setting preferences for printers within ArchiCAD v9
All printers were displayed as being available to the user, however when a printer was selected for use within ArchiCAD the dialog window would close and the selection would be ignored.
The printers are shared from a server which handled all the print jobs. When a user prints the job is spooled locally by the locally loaded print driver (which is checked against the server for the current version). The job is then handed off to the print server who controls the interaction between the job and the network printer.
1. Checked server for current printer driver - OK
2. Check current driver was being deployed to workstation - OK
3. The user was given admin rights to the workstation (and thus full rights to the local printer driver configuration - still experiencing problem
4. Added user to ArchiCAD security group and gave group full control of printer on the server - problem corrected
Note: This is the only program loaded on any networked workstation that requires this elevation of privileges to be able to print correctly. All other applications worked fine with the existing printer setup and permissions (which is also the recommended and default arrangement). This appears to be an issue peculiar to ArchiCAD.
