‎2005-03-07 03:51 PM
‎2005-03-10 06:48 PM
‎2005-03-14 11:34 AM
Ben wrote:It is HP755CM.
Ivan,
What is your printer make/model?
Cheers.
Ben
‎2005-03-14 06:31 PM
TRIBU wrote:This can ONLY be access right settings. Nothing else.
It isn't just one printer problem. It's ALL printers problem ( we have like 8 of them), it really accepts ONLY default printer and its default settings. No paper size and orientation adjustments.
‎2005-03-14 07:25 PM
‎2005-03-16 10:34 AM
Ben wrote:Are you saying that in order to work in ArchiCAD you must have full administrative rights on every ArchiCAD PC in your company?
It has to be.
As Djordje said, it has to be a privilege problem. Sounds to me that you have limited rights and not Admin rights.
Cheers.
Ben
‎2005-03-18 06:48 PM
TRIBU wrote:It all depends how the printers are set up.
‎2005-03-19 05:23 PM
‎2005-03-23 11:13 AM
gkmethy wrote:As long as I feel safe on your server I don't mind
When you change settings in Print setup, ArchiCAD tries to read data from the driver files. these are in the C\ WINDOWS\ systemthirtytwo\ spool\ drivers folder. Do you have read&execute rights to this folder and to the items in it?
Sorry, it seems that the AC-Talk server does not allow me two spell systemthirtytwo with numbers. It gives me a security alert.
‎2005-04-05 05:06 PM
