gpowless
Crash after creating list
This is starting to become annoying.
When I create a pre-defined list from the project map the 1st time and save the view everything is fine until I go to switch views, at which point ArchiCad crashes. This also happens if I try to run a list while the list window is still open. Anyone else experiencing this issue?
Intel i7-6700@3.4GHz 16g
3 Replies 3
Is this a version 18 problem?
Element, Component or Zone lists?
I was just playing with component lists, creating views, switching views, running lists again while original window was open and had no crashes.
gpowless
AC18 problem using an element list - precisely a Total Keynotes list.
Eduardo Rolon
Total Keynote is not made by GS so you might need to get in touch with Jeroen at Master Script also.
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
another Moderator
