Hello LuĂs Dias,
I have seen such an issue before. It is caused by some clash between ARCHICAD's OpenGL Engine and the video card. It doesn't mean that it is incompatible, there's just something about that specific video card (or driver) that doesn't work quite well with this component in case of high polygon count. Of course there's probably some specific calculation that the card can't handle, but from a user point of view it seems random. The development team is looking into whether there's a solution for this, but it will take time.
Most of the time these projects should look fine on other computers (with other video cards). If you happen to experience this on other computers as well, it might be something new, in that case you should contact your local support team.
It is worth checking if you have the latest GPU driver, and if you have enough RAM/VRAM. Also, changing the View (eg. turn off marquee cut as you have suggested), and/or using Rebuild & Regenerate (ctrl+alt+shift+R) might resolve the issue. Additionally, since this tends to happen to projects with a High Polygon count, you might also want to try lower the number of polygons in your View (eg. turn off layers of overly-detailed interior furnitures).
Since this problem is limited to OpenGL, Renders and Views in vectorial Engine should look just fine, so make your final pictures/drawings with those.
Good Luck,
Daniel Alexander Kovacs
GRAPHISOFT
