Installation & update
Date stamp incorrect
gpowless
I just found an anomaly with Archicad file.
Earlier this month I revised a drawing from June of last year. However when I when to open it, the file date was listed as June 28, 2012 even though it had been revised Jan. 21, 2013. I opened the file again today made some changes and when I saved it again the system date was June 29, 2012. The computer system clock registers currently & the .lck file shows today's date correctly.
In looking at the properties it lists the modified time correctly as well.
Can anyone advise?
Intel i7-6700@3.4GHz 16g
GeForce GTX 745 4g HP Pavilion 25xw
Windows 10 Archicad 26 USA Full
4 REPLIES 4
Sounds like you might be looking at the date created rather than the date modified.
There are all sorts of dates for a file but these are the main two.
gpowless
Nope. My explorer was showing the date in the Modified column but that date wasn't changing when I save Archicad files. Everything else showed correctly.
However, since saving the last time when I closed Archicad, it is now showing correctly.
Hmmmm.
Sometimes WE doesn't always refresh.
Hit the F5 key to force it.
gpowless
Did that, wasn't it.
