Dimensioning to masonry opening.
After have door 'D1 Metal 10' inserted into a masonry I am unable to dimension to the masonry opening. Instead dimension marker is only able to select the jamb opening, which is 4" narrower per my setting. I did have the 'Frame depth=wall thickness' deselected in the Door Selection Settings window.
Any suggestions?
I am Mac Powerbook G4 user.
10 Replies 10
`/archiben:
Perhaps I missed it but so far I could not find the controls you describe in my Door Selection Settings window (USA version).
kllment:
Although USA version is different (see my attachment), your attachment prompted to look even closer at my control settings. I am now am able to dimension to the masonry opening just like you show on your drawing after I turned ON 'show all hotspots' under Floor Plan Symbol.
Thank you both and everyone else who tried to help.
