Don't move past the 1010 patch/hotfix
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
ā2007-04-24
05:04 PM
ā2024-07-09
08:59 AM
Aruzhan Ilaikova
- Labels:
Install & Update
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2007-04-25 01:28 AM
vfrontiers wrote:I am sure it is related to the 1183 hotfix. Text was fine for me before the 1183 fix. Upgraded to 1183 and it effected text on every single project. I went back to 1010 and everything went back to normal.
I have recently noticed all my text changing from Arial Narrow to Tahoma.... Could this have been related? VERY FRUSTRATING..
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2007-04-25 01:38 AM
sam66 wrote:I noticed you are on an intel Mac. What you are likely experiencing is the text is finally displaying correctly. Up until the recent patch, the text spacing appeared different on the Intel Macs than it did on the PPC Mac and Windows platform. This made changing platforms with the same file next to impossible. I was working on an Intel Mac while my computer was in the shop and I had to ignore anything that had to do with text spacing until I got my computer back from the shop.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2007-04-25 01:55 AM
Mike wrote:I had noticed that there were some text anomalies in early builds when I moved to the MacBook Pro and 1183 did fix these. The problem is I have a years work spanning many projects on the intel mac platform that I continue to work on. I can't just upgrade and go back and fix the text on each project. Very time consuming.
I will have to stay on 1010 for quite a while yet.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2007-04-25 03:56 PM
AC26 (since AC6.0), Win10
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2007-04-25 08:08 PM
Tried exactly as you asked on a PPC G5 OSX 10.3.9 with the 1183 build and it works fine. I can try it on my PC tonight at home.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2007-05-04 07:58 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2007-05-08 11:29 AM
I also tried your steps to find that 1183 works as expected. In fact, this area got a fix in 1183, and according to my tests, it works fine.
VP, Customer Success, Graphisoft
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2007-05-08 05:35 PM
sam66 wrote:Don't do that. Even though it is a tedious job to fix all text, the longer you avoid this, the more work you will have later on. The problem was not just the difference between PPC and Intel Macs. IntelMAC did not display the text with the settings you have specified. It got spacing and font size wrong. This was a result of a bad function in the OS that we had to circumvent in the latest Hotfix
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2007-05-10 02:41 PM
Who should I bill, Graphisoft or Apple? Because it would take days to go through my current projects and change all the text.
It is not as simple as selecting the text and it corrects itself. It changes alignment, leading and spacing, especially with multi-line text blocks. This all has to be corrected, which is extremely time consuming.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2007-05-25 10:17 AM
1. Many OpenGL issues : no 3D window in OpenGL available, black window or automatic switch to internal engine or very slow or crash or...
2. Regenerating elevations took me 10 minutes (before seconds), even for adjusting a simple sill or pen color in 3DA!
3. Most annoying, I couldn't modify vectorial hatches within materials without crashes. Every project, every attempt!
Back to version 987 and everything works fine again. Still I would like Graphisoft to offer all the patches of the latest ArchiCAD version on there server to avoid this waste of time. I cannot reach patch 1010 wich worked perfect for me!
- Ā« Previous
- 1
- 2
- Next Ā»
- Ā« Previous
- 1
- 2
- Next Ā»
