mattmgut
Drop Down Menu UI
Please see photo attached. Occasionally when I use the drop down menu for "Documentation" and move off the menu, the menu remains. Currently I need to shut down Archicad and restart for it to go away. Are other users experiencing this? Any other suggestions to get the blank menu box to go away?
Thanks!
Matthew Guthrie
RHiZO Architecture
MacBook Pro M2 Max, 32GB
macOS 15.2 Sequoia (24C101)
AC 28
11 Replies 11
Eduardo Rolon
Just had this happen with the Enscape Menu and had to restart AC. At the time I had 2 AC sessions open.
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
mattmgut
Thanks for confirming.
Matthew Guthrie
RHiZO Architecture
AC 28
This was reported before by other users as well, and it seems to be an issue with macOS Tahoe:
https://community.graphisoft.com/t5/Installation-update/Strange-Modal-Ghost-Dialog-Box/td-p/683569
https://community.graphisoft.com/t5/Installation-update/ArchiCAD-28-3-0-amp-MacOS-Tahoe/m-p/683422/h...
mattmgut
Thanks for the response. I am still running Sequoia.
Matthew Guthrie
RHiZO Architecture
AC 28
Eduardo Rolon
When I initially installed Tahoe I never saw the issue, nor did I see it in Sequoia, I am in Tahoe 26.1 at the moment.
AC29 US/INT -> AC08
Interesting, you might be the first person who reported this issue on a system other than Tahoe, which means that the issue is not Tahoe-specific.
In this post it mentions it happens in Tahoe, Sequoia and Sonoma.
https://community.graphisoft.com/t5/Installation-update/ArchiCAD-29-Bug-empty-window-over-working-wi...
Reading those posts it seems it might be a Mac issue with external monitors?
mattmgut
Thanks for finding the post - I need to do better searches. It does happen with an external monitor. Next time I will drag the application to my laptop screen and see what happens.
Matthew Guthrie
RHiZO Architecture
AC 28
Space_Agency
Same issue. Sonoma. No monitor connected. Seems triggered with Enscape.
Archicad V29 /V28 USA
MacBook Pro M1 Max
ram 64GB
Mac OS Sonoma 14.2.1
