ELEVATION CLARITY
WHEN CREATING AN ELEVATION AT AN ENTRANCE TO A PARKING GARAGE SOME OF MY WALLS MUST OVERLAP AND IT SHOWS THEIR OUTLINES. IS THERE A SETTING THAT CAN TURN OFF THOSE INTERSECTING LINES? THANKS FOR YOUR HELP.
7 Replies 7
Link
Model it correctly!
No other way AFAIK - it's a feature!
Link.
Ben Cohen
solid element operations may do the trick.
Ben Cohen
Mac and PC
Archicad (Latest Version) aus
www.4DLibrary.com.au
__archiben
EVAN wrote:
...SOME OF MY WALLS MUST OVERLAP...
your builder isn't going to overlap his walls, is he? that would be physically impossible . . .
axioms
~/archiben
b e n _ f r o s t
I suppose you're right, I will try to remodel it. I just thought there could be a shortcut. Thanks for the input.
What are solid element operations? Thanks.
TomWaltz
I'll give you a hint.... they are listed in the table of contents of your user manual... then described in decent detail later on in the book.
Tom Waltz
Hey; you're right...I never knew this command...it's pretty great....Thanks very much.
