Error Parsing Language
I get this persistent dialog box stating " Error Parsing Language File Language Will Default to English" at start up. I need to keep clicking on it and it eventually goes away and the program opens up.
How can I get rid of this pesky message ?
I would bet that you have some 3rd party add-on installed, as ArchiCAD does not use language files - rather, it has a different version for each language.
Move all CadImage, Cigraph, Encina and other 3rd party add-ons from your Add Ons folder into a temporary folder. Start AC again. Do you get the message? (I imagine not.) Quit, and restore add-ons until you see the message and determine who is causing it ... and then contact that manufacturer if indeed that is the case.
Karl
Thank you for your response. That was exactly the problem. I really appreciate the help.
