AS_2024
Error Warning - Launchpad
Hi All, I received the below warning for the first time opening a file at my office and I cannot figure out what it is from. my CI tools is up-to date so i cannot think of what it is from as I could not find mention of it in the goodies list.
if anyone knows what this is and where/how I I would need to update it that would be amazing.
thanks
1 Reply 1
It seems to be an add-on from Central Innovation.
You are opening a file that must be using a slightly newer version than you have on your machine.
So as the warning says, you should update the CI add-on.
If your add-on is showing as up to date, then you should contact Central Innovation.
