Installation & update
Finder very slow after update 6001
fabioferrini
after 6001 AC22 upgrade on my iMac (Retina 5K, 27-inch, Late 2014), my finder on macOS Mojave 10.14.5 became very very slow.
If I try to open a new file from my finder I must wait about 10 (!) seconds to be able to select it!
note that I've no delay problems with AC 21 or AC23 BETA4, or with any other applications
I've try to re-install archicad 22, re-install MacOS Mojave, replace any kind of finder.plist preference, but the problem persist
Thanks in advantage if someone could help me
Fabio Ferrini
Eduardo Rolon
Check if this helps.
https://archicad-talk.graphisoft.com/viewtopic.php?f=13&t=63149&p=293048&hilit=slow+finder#p293048
This could be an old 22 bug that resurfaced
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
another Moderator
6 REPLIES 6
dkaramaneas
Fabio,
YES EXACTLY THE SAME THING !!!!
Yes i just posted the same thing. Very annoying. There was a work around for when opening the dialogue box internally. But that was not the problem.
Have you had any further insight?
Daniel karamaneas
Architect.
Steve Jepson
I have found several things that I think are rather obvious and important bugs in 6001.
I think it would be good to have a Bugs/Problems category for each version of ArchiCAD on this Forum Board Index so they don't just vanish into the mix of other posts. Problems with how the program functions ought to be the highest priority, not how do I do this or that with the program.
Steve,
I am reading every single post on ARCHICAD-Talk and if I see something that is a bug or may be a bug, I always report it to GRAPHISOFT. So they will not get lost.
So if you post them in the thread, they will reach GRAPHISOFT through me.
Steve Jepson
LaszloNagy wrote:
Steve,
I appreciate that you are one of several important ways that bugs are being reported.
Thanks for doing this. Some of us don't always have time to make verifiable bug reports that include .pla files, pictures, videos and a narrative on how to reproduce it. And even with all of that the report may not qualify as a "bug" in the context of beta testing and thus be dismissed. If it was already a bug in some earlier version it does not qualify as a "bug". So bugs that are not "new bugs" are not reported in beta testing.
Bug reporting should be open to everyone and there should be a reward for all confirmed bugs new and old. And they should all be posted here on this forum for all to see and help to confirm.
Perhaps a credit toward the cost of their next upgrade for each confirmed bug, and 20 or so confirmed bugs gets you a free upgrade.
Eduardo Rolon
AC29 US/INT -> AC08
another Moderator
fabioferrini
GrEaT!!!!! Thank you so much ejrolon, now everything works fine!
