Ben D
Font missing/substituted problem on new install/update
We have a problem in our office that seems to occur any time we set up a new machine with archicad.  I've seen it with AC27 and 28.
We use a font, Century Gothic, as our office standard. This is not a standard macOS font and is installed via font book as part of the machine setup.
After archicad is installed and an existing teamwork project loaded up, much of the text in the file seems to default back to Helvetica, as if archicad cant find Century Gothic and is auto substituting.  What is super odd though is that this doesnt affect everything.  I thought it was certain element types - typically dimensions and text fields, but seems not.  At a guess, it seems to affect standard archicad elements, but not things like CI tools keynotes labels.
It seems to be a local machine display substitution thing, because if the file is opened on another machine, all the fonts show as Century Gothic.  if the elements are edited on the problem machine and changed to century gothic, the change sticks.  it seems like the local century gothic fonts are being flagged as different to the century gothic font in the project, and so archicad thinks the font is missing.
this is happening on multiple recently set up new machines, and on large projects, it is a huge amount of work to manually go through hundreds of drawings, check and update all the fonts.
is there any way to force archicad to either do a global font substitution, or somehow recognise that the font on the local machine is the same as the font in the project?
any help much appreciated
Ben
Operating system used: Mac Apple Silicon Sequoia 15.5
BIM Manager / Senior Designer @ Neeson Murcutt Neille, Sydney Australia
AC27-28 AUS + CI Tools, BIMcloud SaaS
Apple Mac Studio CPU: M1 Ultra 20C GPU:48C RAM:64GB OS:Sequoia 15.7.2
PC CPU: Ryzen 9 7950X GPU:RTX4080 RAM:64GB OS:Win11
Setup info provided by author
1 Solution
Ben D
Using the find and replace tool isnt necessary.  We found that if you left the teamwork project, made sure the correct fonts were installed, then opened an empty Archicad file and went into the Local Data Manager, then cleared any local files for that project, closed that file then rejoined the teamwork project - this solved the problem.
Go to post
3 Replies 3
Mercyfall
I got similar issue when setting up new M4 macbook.  After I reinstall Archicad(27), and reinstall the custom font via fontbook, the program can't recognize the font in which the .pln file was editted on the machine. I'm a new mac user and the issue dose not happen on windows. So I'm not sure it is a system problem or an archicad problem.
I use archicad crossplatform, and I know there are differences between how mac and windows recognize fonts. I tried the official font replace tool but not works properly (Replacing missing fonts between MAC and WIN - Graphisoft Community).   HOPE we can do global font substitution instead.
Since AC24
MBA M4; PC 13600K
GeoffG
I came across this thread when I encountered the same issue, and thought I would post the solution my colleagues and I found.
Effected user should:
1: Leave teamwork project in question.
2: Ensure font installation is validated by opening Apple's 'font book', right clicking newly installed font and select validate.
3: Restart machine.
4: Re-join project. In our case text not created / edited by affected user reset to correct font. Text they had created / edited remained as Helvetica.
5: Use find / replace tool to change helvetica text to correct font. In our case we were lucky this was limited to a few views.
Ben D
