2010-08-04 05:35 AM
2010-08-04 06:02 AM
2010-08-04 07:48 AM
2010-08-04 06:57 PM
rylink wrote:
Using Archicad 14
My framing is attaching to my roof membrane and is keeping my roof framing from gavitating to my top plates. I need to reverse the roof membrane with framing.
I use the roof wizard which works perfect, except the fact that its on top of the roof material instead of underneath resting on the plates like it should be. If I turn off the roof material layer, roof framing still does not drop to plates.
Does any one know how to fix this, or suggestions how to flip this around. Would very much be appreciated!
To see 3D picture click on download pdf. (all the way to the RIGHT)
Ry
2010-08-04 07:07 PM
rylink wrote:rylink wrote:
Using Archicad 14
Ry
Barry, The roof timbers did not lock under roof materials, but locked on top, should be the other way around, right. Also the timber won't drag down because the roof is attaced to the walls, maybe there's a priority problem?
2010-08-05 10:58 AM
 2010-08-06 02:18 AM
2010-08-06 02:26 AM
2010-08-06 02:43 AM
2010-08-06 04:07 AM
