Installation & update
Freezing/speed issues in 3D orbit on 4023 on Mac 10.14.3
I have a user that showed me her laptop is freezing and/or slowing down a lot when she views a model in 3D. Zooming all the way out makes it go faster but when she is inside the model, orbiting and panning is slow to the point of non-functional.
Is there a level-of-detail setting or a hardware rendering option to help speed it up? Other designers are able to open the same base plan and navigate 3D as normal, and other users with the same model MacBook are not reporting this problem.
1 REPLY 1
Lingwisyer
Guru
Check if their Advanced Redraw Options are the same?
Ling.
