Grasshopper Add on for AC26 Not Loading Correctly in Grasshopper
Jarrod Phillips
Hi All,
as the subject suggests, I have installed the grasshopper add on for AC26, the install was fine, all looks okay in AC26, however when I fire up Grasshopper I get the following error:
The Archicad tab is showing in grasshopper however it doesn't appear to be loading the Archicad drop down menu on the task bar. Obviously, I cannot connect to Archicad without this. Any ideas how to fix this?
Cheers!
Jarrod
BIM Manager | Graduate of Architecture
Fulton Trotter Architects - Sydney, Australia
Archicad 15 - 27
Priscila Amorim
Did you find any solution? I am having the same problem as you...
Hi, would it be possible to request more information regarding this issue? The version of the Rhino and Grasshopper installation you wish to run The Grasshopper-Archicad Connection with would help. You can access this info while running Rhino and Grasshopper using the About... menus. Thank you!
