Installation & update
Green Bands in 3D
Tell me what to do about it if there are no changes even after the update.
This is a known issue with Intel graphics:
Dec 07, 2020 post from mnguyen states:
This defect is caused by a faulty Intel driver. Please make sure to have the latest Intel GPU driver installed. You can find it with the following link: https://downloadcenter.intel.com/downlo ... CH-Drivers
After installing, the green stripes should not appear in 3D environment.
https://archicad-talk.graphisoft.com/viewtopic.php?f=13&t=71458
Try to update the graphic card drivers on your computer, bad drivers are what usually causes this phenomenon.
