Installation & update
Hot fix 4010
My system confirms I'm running 64 bit windows.
However the hot fix says application can't run because it's not a valid 32 but application.
6 REPLIES 6
However.....When I try to run Hot Fix.
I get the following message.
First time this has happened.
What did I miss?
Eduardo Rolon
Try redownloading the file. There have been a lot of download errors recently from GS.
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
another Moderator
Thanks for the reply ejrolon.
That's a least somewhat comforting....
However tried that 4 times and to different directories as one time it told me to try that.
However, now I'll keep trying.
Eduardo Rolon
Verify the file size of the download and compare it to the size indicated in GS page to verify that is the problem. I have had to try more than 4times when this affected Mac users, which was fixed, instead of Win64. If nothing else works try using a download manager.
If it is downloading completely then the next likely culprit is the java installation, do a search I think somebody had this problem recently.
AC29 US/INT -> AC08
another Moderator
For 16 Hot Fix 5, ironically, the fifth download was a success.
Thanks again ejrolon.
lec
vistasp
I can second that. My hotfix for 16 failed a couple of times until I used a download manager. Most browser have some level of download management but they're not robust enough to handle all eventualities.
= v i s t a s p =
bT Square Peg
https://www.btsquarepeg.com
