How to enlarge a 2D object ?
4 Replies 4
You might need to be a bit more specific. A 2D GDL Object (Library part) or a something you've drawn in 2D?
How to enlarge a 2D object (some line i have drawn in 2D)? Thks
Select the lines (or whatever)
Edit > Reshape > Resize
then either define graphically or enter a ratio or percentage.
Hope that helps.
Pete.
TomWaltz
I think the confusion about your question was because in Archicad "object" refers to something placed with the Object Tool, like a beam, a toilet, or a chair.
Some of these Objects work with the resize command differently than others. For example, a W-beam does not resize because its dimensions are hard-coded based on the size beam you selected.
If you want to generally refer to lines, walls, objects, slabs, etc., the Archicad term is "elements."
Tom Waltz
