‎2015-09-17 09:52 PM
‎2015-09-18 09:58 AM
‎2015-09-18 04:39 PM
‎2015-09-18 09:00 PM
‎2015-09-18 09:04 PM
laszlonagy wrote:No. They are all where they are supposed to be. Everything is relatively near the point of origin. There is noting out there in that extreme zoom. It is probably a harmless anomaly. There is nothing between the zoom to extent view and the extreme limit. It only appears as if there is.
Can you just select all those Section and Elevation Lines and move them back close to the Project Origin where they are supposed to be?
‎2015-09-19 12:08 AM
Steve wrote:I tried this but for me everything appears just fine.
Did you try it your self ?
I tried it with the default Template file with nothing in it and I can see the elevation markers in the upper left hand corner of the screen. Very tiny but there.
Turn on all layers and go to a Project Map were you can see what is there.
You may need to choose a different Project Map.
Then scroll out with your mouse to the extreme limit - not just zoom to extent.
‎2015-09-19 12:16 AM
‎2015-09-19 03:29 AM
laszlonagy wrote:There is noting wrong with my graphics card or it's drivers.Steve wrote:I tried this but for me everything appears just fine.
The default Template has all 4 Elevation Lines close to the Project Origin and zooming out until the Zoom factor is 0.0000% and ARCHICAD beeps does not give me any artifacts.
Edwin might have given a good tip: try to update your graphics card drivers as this may only be a screen artifact, not an element being at the wrong location.
‎2015-09-19 04:37 AM
‎2015-09-19 06:57 PM
