I can't install Archicad 22
Ali_youssef
I tried to install Archicad 22 but when it get started the installation stopped and this
message appeared
 so what should i do??
It seems self-explanatory.  Your Windows OS is not up-to-date...so you should run Windows Update, assuming you have a legal license?   If your copy of Windows is a 32 bit OS, you need to obtain the 64 bit version of Windows 10.
See also this article - make sure antivirus is disabled, etc:
https://community.graphisoft.com/t5/Setup-License-articles/Archicad-22-Install-and-Startup-Troublesh...
This is the problem 😅😅my windows is old and i have to up date it.
Thank you for helping my🌷🌷
