Icon Text boxes
Hello there,
The text boxes that pop up whenever I hover over a tool icon have disappeared, Is this related to a resolution issue or graphics?
How do i get them back?
5 Replies 5
In the HELP menu there is a "Show/Hide Tooltips" option.
Hi Barry
Thanks for your response, They are switched on but is showing a really tiny rectangle, its like the textbox is 1mm higher
Then this post will help you out.
The solution is in the last message.
See if these threads address your problem:
http://archicad-talk.graphisoft.com/viewtopic.php?t=25254
http://archicad-talk.graphisoft.com/viewtopic.php?t=30542
Woops I forgot the link.
Karl saved the day though - thanks Karl.
