Installing AC9 on windows xp 64bit
hi! how can make AC9 to work on winxp64. i can install AC9 but unfortunately it doesn't recognize the keyplug even by using wibu 64bit drivers.
4 REPLIES 4
Djordje
It should. Are you sure you installed the drivers properly?
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
AndorSzoke
Dear syber,
The WIBU driver installed by the ArchiCAD installer must be removed, and the 64-bit version must be installed.
I hope this helps.
Best regards,
Andor Szoke
Technical Support
Graphisoft R&D
AndorSzőke
Product Management
GRAPHISOFT SE
Follow us on Twitter
GRAPHISOFT HelpCenter - the ArchiCAD knowledge base
Not sure if you updated your WIBU drivers allready. . .
click here for the Itanium 64-bit WIBU driver
click here for the AMD 64-bit WIBU driver
Hope that helps you out more.
Here too. New last Friday April 28.
http://www.graphisoft.com/support/archicad/downloads/WIBU.html
