2008-12-22
04:34 PM
2024-04-26
11:34 AM
Aruzhan Ilaikova
2009-07-28 05:14 AM
2009-09-08 03:10 AM
gkmethy wrote:Hello, I bought a brand new apple macbookpro yesterday and the first thing I tried to do was to install archicad student version 12.
We have found that the 10.5.6 system update on the Mac PPC platform causes that the ArchiCAD installer (both ArchiCAD 11 and 12, presumably older versions too) hangs when it gets to the point of installing WIBU components. The workaround is installing the WIBU components first (there's an option to install WIBU separately in the ArchiCAD installer). Intel Macs are not affected.
This, and other possible install problems are described in the Archicadwiki article:
http://archicadwiki.com/ArchiCAD%2012%20Install%20Problems
2009-09-08 03:45 AM
another Moderator
2009-09-08 03:56 PM
ejrolon wrote:
You could try to .. run in emulation but it is recommended and will cause less headaches that if you download the correct version for your system which is Mac OS - Intel.
2009-09-08 04:01 PM
another Moderator
